module 10 unit 8 'DO'
genevieve anore shared this problem 4 years ago
Known
I Did the do test mode of module 10 unit 8 and I keep on getting a 50%, even though it's the correct answer. I also tried the wrong answer which seems to be fine, however whenever I click the right answer it immediately grades me 50% without even proceeding to the next scene.
Replies (1)
It is important to complete both Do-play and Do-test, in order to get the greentick. Also, the green tick will only appear when you get the passing score, which is 80%. We encourage students to pass the DO, which means, unless they pass with 80%, it will prompt them to try again and do better, and the greentick will display when the student gets a passing score.
