System error/bug
Aron Joshua S. Layugan shared this problem 4 years ago
Known
Module 7 unit 5 - nag wewell done po yung activity (THINK) pero hindi na cocomplete yung green circle (Tried many times restarting and refreshing it)
Module 7 unit 17 - same problem with unit 5 (collaborate and explore)
Module 8 unit 16 - hindi ma-click yung submit (do) then may nakalagay na unresponsive page
Module 10 unit 7 - same problem with Module 8 unit 16
Dashboard - all the modules are done (except for the bugss!) pero hindi umaandar yung chapters completed :(
Replies (1)
1. Watch: You need to watch the entire video, to get the greentick.
2. Think: You need to attempt the Think component end-to-end, to get the greentick.
3. DO: It is important to complete both Do-play and Do-test, in order to get the greentick. Also, the green tick will only appear when you get the passing score, which is 80%. We encourage students to pass the DO, which means, unless they pass with 80%, it will prompt them to try again and do better, and the greentick will display when the student gets a passing score. But still, if the greentick is not displaying despite getting a passing score, it could be a connectivity/browser related issue. Please do not worry about the DO score. The score will automatically get captured in the backend.
4. Collaborate: You need to submit your response after performing the activity, to get the greentick.
5. Explore: Once you open the Explore component, and click a few links for additional learning, you will get a greentick for the Explore component
