Incorrect Marking and Wrong Question Options
kunal shah shared this idea 7 years ago
Under Consideration
No marks given even when partial answer is correct for my quizzes. There is mismatch between question options i.e. One question bears options or answers of another question. This is a huge hault
Replies (4)
Dear Kunal,
Please share the quiz details so that we can support you further.
Thanks
Team Wadhwani
It’s with almost all quizzes in advanced course in Entrepreneurship registered under mail id kunalshah@jklu.edu.in but I want you to kindly rectify firstly the final assessment quiz. I would be glad if a person can contact me over phone for detailed solution
Dear Kunal Shah,
Request you to please discuss with your Wadhwani Foundation Program Manager so that he can help you further. In case there are any technical issues while doing the quiz, we can help you. However, if you furnish the exact details of the quiz, we can clarify further.
Thanks
Team Wadhwani
Final Assessment quiz of Advance course in Entrepreneurship where Zero marks are allotted even when My Partial answer is correct. I have contacted program manager but the problem is not understandeable and being ignored by him. The Marking error is a technical fault so review it and allot correct marks
Waiting for your reply, I have mentioned exact quiz I want to get rectified
Hi Kunal,
Please note, there are no technical issues in the marking system. This has been verified and sealed. Please share a screenshot of the above mentioned question and we will discuss with content team and revert on possibilities.
Thanks
Team Wadhwani
I would also like to add that there is marking error too and I can prove that to you with screenshot with the error of your system. If the thing is not solved through regular communication I have to take other ways to get it sorted. If I am not able to prove it to you, I will have to prove it to some dedicated authorities
I would also like to add that there is marking error too and I can prove that to you with screenshot with the error of your system. If the thing is not solved through regular communication I have to take other ways to get it sorted. Thank you  for your response
f9fe50d4d0f24ecf93dcf21977d24108
Dear Kunal,
We understand your concern and hence this request to discuss with your Program Manager. They will be able to connect you with the concerned experts. However, there are no technical issues in the marking system since we have checked thoroughly and students from across the world have completed the quizzes and final assessment as well. This could be due to certain questions holding negative marks or 2 correct answers. If you mark one wrong, marks wont be granted.
In case you have problems connecting with Program Manager, please do revert and we will connect you to Regional Head.
Thanks
Team Wadhwani
