Issues
Josemari Antonio E. Marcelo shared this problem 4 years ago
Known
There are multiple Collaborate, Do and Explore that I am not able to get a check.
Replies (1)
Watch: You need to watch the entire video, to get the greentick.
2. Think: You need to attempt the Think component end-to-end, to get the greentick.
3. DO: It is important to complete both Do-play and Do-test, in order to get the greentick. Also, the green tick will only appear when you get the passing score, which is 80%. We encourage students to pass the DO, which means, unless they pass with 80%, it will prompt them to try again and do better, and the greentick will display when the student gets a passing score. But still, if the greentick is not displaying despite getting a passing score, it could be a connectivity/browser related issue. Please do not worry about the DO score. The score will automatically get captured in the backend.
4. Collaborate: You need to submit your response after performing the activity, to get the greentick.
5. Explore: Once you open the Explore component, and click a few links for additional learning, you will get a greentick for the Explore component.
