Results Problem
DIEN P. shared this problem 4 years ago
Known
Module 5 Unit 7 Do Test. I got 100 but when I tried to answered it again it became 62%.
Replies (6)
Take note: I tried it 3 times with the same answer from when I got 100. It always resulted to 62%.
Same problem on Module 5 unit 7.
What was the problem
2
Hi the problem is the score is not accurate. I think my answer are correct but the results always says that I should try again.
We have taken note of this issue and will update these in the next round of iterations. As of now, you are requested to focus on the learning, and move on to the next component.
Noted thank you.
You're welcome
